Fuel in oil!!!
Duramax52513
Jun 23, 2013
99
I changed my injectors about 3 weeks ago and I have fuel in my oil. Any ideas on why this occurred, does this mean the injector cups aren't sealed?
jamesashtoncan
Jan 15, 2016
22
Could be. What brand of injectors did you get? Also id check the fuel regulator. Mine had a broken gasket causing it to leak fuel in the oil
Sent from my SM-G930V using Tapatalk
Robby05
Jul 25, 2014
498
Spokane, WA
Torque every thing down to spec under the valve covers? Was it leaking fuel into the oil before you replaced injectors?
Kamilmk
420
Seymour, CT
Just went through the same issue with Awenta on my truck. We bet on leaky return line, exactly what it was. Run a vacuum test on each side. Check if it holds it.
15psi for 30 minutes, I believe that's it.
Sent from my SAMSUNG-SM-G928A using Tapatalk
Duramax52513
Jun 23, 2013
99
Injectors were from Lincoln diesel, yes there was fuel in my oil before I put new injectors in, that's what made me change them.
Awenta
4,090
CT
Vacuum test. If not you've got leaking high pressure lines or a leaking cp3
2,213
If you find it is a leaking return line gasket, give em another 1/8 to 1/4 turrn. The specified torque only just barely starts to crush them. I think this is why so many have this problem.
