Fuel gauge not working
Ed Janus
Mar 24, 2014
I have a 2005 lly duramax and when I start the truck the fuel gauge goes up a little bit then drops down to a half a tank under empty with the needle facing down . Is this the stepper motor in the dash cluster ?
3,727
296
I don't know if a regular code scanner would do it, but EFI or a data logger will. You want to read the fuel level reported by the ECU. There are (at least) 2 PIDs, one for fuel sender voltage, and one for fuel level in liters.
The liters should match what is in the tank. I don't know the correct voltage range off the top of my head, so you'd have to look that up.
