Fuel Gauge not reading correctly
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
My fuel gauge is not reading correctly, when all the way full it only reads 3/4 full. I checked the tune I am running against my stock tune and the fuel tank settings are all the same. Anyone have any ideas?? -Jeff
Sean8816
Junior Member
Aug 8, 2006
My fuel gauge went bad at 22,000 miles, it would stick around 3/4 tank and not move down. I was told by the dealer this is a common problem for these trucks, so it could very well be the gauge not your tune. My speedometer also broke shortly after.... twice. I'm a huge fan of Chevy gauges. Oh, and if it is your fuel gauge, make sure the dealer reinstalls your tank property. I got a couple of miles away and heard something start dragging....turns out it was only my diesel tank!!
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
how much is this gonna cost me? I cant believe that the gauge itself would go bad. maybe the sending unit? If it is the gauges and I replace the cluster would that fix it? -Jeff
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
I had the SU go out on mine. It was reading higher than it should've. Towing a 20' box tailer w/ about 200 miles on the tank and it said I had 3/4 left.........I wish.
Los Lobos
R & D Baby
Sep 22, 2006
3
Wilsonville, OR
If you played with the settings in EFI live at all it will do this if you're off anywhere in the setting. I played with it last week and ran into the same issue. Next time my tank is empty and my pump is full I will try and get readings on a fill up to adjust the #'s closer. I haven't checked further but down in the setting there is a value that drops it down but I dont remember. I'll check more into it when I cna get the other comp out.
