LLY: Fuel gauge help and programmer
Mondo0928
May 17, 2016
27
I have a 05 2500 lly duramax crew cab, well when I got the truck the fuel gauge was working great and all then I put fuel in and it was good. Well just the other day my girl said she put fuel well the needle is stuck on Image1463535639.809631.jpgImage1463535655.775421.jpg and it won't move on the gauge and the edge attitude cts programmer. Please help me I'm new to this forum and it's bothering me because what if I needed to go out of town and I run out of fuel what can be the problem and where can I start? Thank you
Mondo0928
May 17, 2016
27
And does it have to deal with my truck always saying water in fuel because that didn't happen till jiffy lube put a new fuel filter and it won't go away I tried fuel additive also so I need help on that to if you can.
2,137
Fuel gauge and water-in-filter sensor are unrelated.
There are two wire that go into a reed switch at the bottom of the fuel filter. Short them together and the warning will come on.. jiffy lube may have screwed up the sensor or wireing or there may actually be water in the filter. Inspect the wireing and try draining the filter.
Mondo0928
May 17, 2016
27
I'll sure will look at it thanks for one problem lol
