It's taken me a couple of years, but I'm finally getting around to doing some of my own tuning on my LB7 (2003). I've got EFI Live / a V2 Flashscan. But before I started changing anything, I thought I'd first spend some time datalogging and getting my head around what's actually going on (versus just blindly changing some numbers).
Most everything has made sense so far, but there is one thing that has me puzzled and I haven't found a good answer searching just yet. What PID should I be logging for the fuel flow rate? Say, for example, to use to create a map of the Main Injection Pulse (B0720) table? I'm currently logging Throttle Base Fuel Flow Rate, Main Injection Fuel Flow Rate, and Main Injection Fuel Flow Rate 2. I found an old post stating the Main Injection Fuel Flow Rate PID has a bug that won't allow it to log over 80 mm3, and my logs show that to be true, so that one is axed. But what about the other two?
Is Throttle Base Fuel Rate what's being commanded via the TBIQ table, while Main Injection Fuel Flow Rate 2 is the actual fuel rate after being potentially limited by ECT, MAF, or TLIQ tables? Is that how it works?
Thanks in advance!
Thanks in advance!
