Fuel filter housing LB7
Studders21
Jan 10, 2015
5
Texas
Where can I buy a fuel filter housing? I know the the LB7's are higher than hell. I heard you can put a lly on it to fix some bugs, and it's cheaper. If so, where can I buy one at, and how hard is it to install? (Does anything change, stuff like that)
motoking_1990
1,957
5
Terre Haute, IN
Most here delete to make room for other goodies. And thier lift pumps already filter. Some use both lift pump and factory but thats a whole other topic. Depends who you ask. As for the lly I cant comment there I have no experience there other than rebuilding one.
RHallenbeck
Aug 21, 2014
50
Beaumont, Texas
You can get them online for around $110.00 or so but if in a bind you can go to any GM dealer and they have them for $150ish.. Still not a bad considering that is a new GM filter and new GM water sensor also.. As far as I know it is a bolt on replacement but you will have to lengthen the hoses some. I would change the hoses anyway due to them getting soft and sometimes sucking closed when hot..
