Must you use the fuel cooler or can you delete it. If it is a must is it better to go bigger?
R rdohara New member Jun 17, 2009 122 0 0 Feb 19, 2010 #1 Must you use the fuel cooler or can you delete it. If it is a must is it better to go bigger?
S S Phinney Active member Aug 15, 2008 4,008 18 28 Quncy, Fl Feb 19, 2010 #2 Cooler fuel is better for use. I wouldn't take it out and it can't hurt to go larger .
