You can rescale it, but you will also need to add a 40 Ω resistor or so inline. If the ECU sees close to 0 Ω, regardless of what you scale it at, it fails a diagnostic and reports the fuel as 0%. At least on the LS motors. But add a resistor, then rescale it as if you had a 40-130 Ω, should work great.
That's good to know
