Just got it back together after head gaskets. I had a thread on diesel place about it not cranking but got that solved (bad connection @ ECM) now it cranks over but I can't for the life of me get the fuel system bled out. When it was apart I dropped/cleaned the tank and blew out all the lines. It now has 10 gallons of fresh fuel in the tank.
Ive bled it many many many times and there is no more air coming out of the bleeder and the hand pump pressures up. Ive also confirmed that there is fuel getting as far as the cp3 but there is NOTHING on the other side of it. I pulled a couple injector return lines and while cranking get steady fuel coming out of the lines.
I pressure up the filter head and after cranking the primer pump is soft again. I can't see any leaks anywhere around the filter head.
Im sure I've done more to try to get fuel to the rails but my mind is a bit scattered from being so stumped. My theory is that fuel is getting to the CP3 and then being pushed from there down the return line and for some reason nothing is getting past the pump in to the rails.
Help please :dontknow:
