Front Tire Pressure
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
Was wondering what pressure ya'll run in the front tires while pulling? Also how much air if hanging weights? And also where can i find a set of bump stops for the front A arms? I'd seen them before, but cant find them now. They are adjustable rubber blocks. Hope that helps. Thanks!!
AdaMax
Nov 26, 2010
412
Caldwell , Oh
I run 16 - 20 psi up front depends on how much bite it looks like the track has . For the front suspension stops I built mine out of solid 2" cold rolled steel .
05chevy
1,086
I run 20-35psi. depending on the track. I run mud grapplers so they bite pretty hard
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
I made my front bump stops out of hockey pucks. The front end doesn't really drop when I hang the weight and they have a little give to them so when im driving in the pits and going down the track my teeth don't chatter.
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
I'll plan on 16-35 psi then, depending on the track. Anyone comin to Bedford County's fair and pullin this year? I did find the bump stops id wanted. Bigchevyhitch.com has them. Just waiting on a reply.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
42
Norvelt, PA
Half of rear pressure will get you close, then make adjustments per the track. mark your tire to rim with a marker, youll be surprised, dont go too low if its bitin!
We should be at bedford.
millerman04
< The Man Cave
Jul 14, 2010
1,039
Clearville, Pa
Hope to see ya'll there. Caleb you better be there. Wife's gotta defend her last years win. Maybe i'll park next to ya and learn some things quick while im there. :thumb:
