Looking for the differences in the front pumps between the 05 and older and the 06 and up. My wear plate and ring gear are vibrating on the converter and causing a terrible whining that gets louder with rpm. Have a good 05 pump that I would like to use, if they are interchangeable? Heard the metal in the older pumps was better and holds up to higher pressures better ? Thanks
