Help: Front End Lift On Launch
BLKLMM
<<< Slow Mamba
Jan 31, 2010
2,142
Oceanside
Hey guys I am stumped:confused: Cant seem to keep front end down:mad: I have t bars all the way down and Qa1 singles up front and just added a PPE centerlink:eek: The rear have the overloads pulled and have JMK traction bars .This pic shows a 15ish pound boosted launch:mad: What can I do to lower my front end down and 60 better:confused: Thanks any input will be appreciated
DetailsUnlimited
1,264
Benton, Ar
I had the same issue and had to lift the rear and inch. To much squat in the rear. Have the rear lowered with 3 inch drop shackles and moved tothe next bolt hole. Much better!
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
We straped my friend Randys truck with all stock suspension and he cut 1.63 60ft's with it on a 7.50's pass in the 1/8th.
darkness
1,317
380
vegas
Put a strap from either top or bottom a-arm to a point on the frame....if you strap it. What if you put your helper back in and clamp the front of it? That would stiffen the back a little bit.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
What he said. How I straped them is I get a longer shock bolt at the bottom. Use two nuts, one to tighten the shock back up and a washer then my strap and then another washer and nut to tighten it at that point. I then at almost the top of the shock tower brace on the backside, I drilled a hole to use a half inch grade 8 bolt. Then ran my stap to that point and bolted it there. I belive with Randy's truck there was about 1/4 to half inch rise in the front on take off. Put your helper back in and clamp the front like Darkness suggested
to give the rear some stiffness.
BLKLMM
<<< Slow Mamba
Jan 31, 2010
2,142
Oceanside
Thanks Josh:hug: I was going to also drop a hole on my shackles to give it a better angle on bars:thumb:
