Help: Front Diff Blew Oil Out Of Vent
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
Just like the title says, after work I noticed that there was a little bit of oil running off my driver's side inner fender. I followed the vent hose up from the front diff and there was oil at the end. It is gear oil. I will check the level tommorow when I have light again. Any idea what could have caused it? It's the original fluid with about 44 000 km on it. I haven't been driving any differently, and the truck hasn't gone through any deep water ever. Is there anything I should check? Thank you.
Daniel:(:confused:
9,905
151
Well, When mine did this last winter, I had one hub that would not disengage and it stayed locked until the shaft broke and all the bearings welded themselves together. Then it overheated and ralphed oil out the vent and past the seals.
Hope this isn't what happenend to you-unless it is covered by warranty like mine was.
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
You're scaring me Dale. I jacked the truck up today, and both front wheels turned freely. Fluid level seems ok. Is it possible something temporarily plugged the vent and it presured up, then blew a bunch of shat out of there?
LBZrcks
Jun 2, 2007
5,297
12
SoCal
when my diff blew my wheels would spin freely but when in 4wd, it would only spin the rears. but i didn't get anything come out the vent
Jared Duramax
<---- $$$ Whore!!
Feb 13, 2008
1,052
Matthews NC
mine did this after the drag strip made a mess allover everything on that side.
and some how i also managed to get green grease all over the bottom of my fender wells after that run:confused:
