Front Bumper Build
ryanship
Feb 23, 2017
9
Hey everyone,
I'm new to this forum, and I thought I would share what few pictures I have of the front bumper construction that I built for my truck. I am planning on building a rear bumper over my spring break in March (college student who doesn't get enough shop time), and I am planning on posting that as well.
I began my build with the idea that I wanted the ranch hand bumper look by using pipe as my main construction, but didn't necessarily want the additional length a ranch hand bumper will add to a truck. Parking is tight here in Indianapolis as is with my crew cab long bed, and the less cars I can bump during a 5 point turn the better.
I started with a quick model of some basic dimensions that I took off of the stock bumper. I used SolidWorks to let my mind guide the model, and this is initially what I came up with. Of course, a few things changed as I actually built it.
I bought some pipe from a good ole boy down in Kentucky I met off craiglist who made his living as a pipe fitter. He had an endless amount of metal racks and piles of old pumps that set off along a trail in the woods behind his place. Apparently he would buy out extra material from a job for pretty cheap, and I wouldn't doubt that he could make a good amount of income on the side just by reselling it all. So I picked out some 4" I.D. pipe he had back there in the woods, and we drug it out with the skid loader. I told him I was gonna take 30' of the stuff off his hands (leaving plenty room for error in my cuts), and he even cut it down into sections on his band saw that I could wrestle in and out of the truck.
This was my first time working with pipe. I had bought a small horizontal band saw recently and decided to take what I thought was the easy way out to cut the angles I wanted. However, I quickly learned that the tool is only as good as the man using it, and that there was a huge learning curve before me.
Here is the truck when I started after removing the stock bumper, and also the first piece of pipe to start my build. Unfortunately I have no pictures of the mounts that I made out of some quarter wall box tubing I had lying around.
Next, it was time to cut each side piece to run along the remainder of the front end.
Once everything was tack welded together, it was time to burn it in.
This is what it looked like on the truck the next day when I finished welding. I should mention that I used a Miller Dynasty 200 tig/stick machine to weld with.
Now, my lady said that I ought to paint it before I went back to college after my summer break, so I just asked her to do it instead. The next day I got new tires and took this picture in the car wash after spraying the blue paint off of them.
I drove around for 5 months with only the pipe construction on the front end of my truck. I study Motorsports Engineering two hours from home and my garage, so I had to get by with what I had accomplished thus far until my Christmas break gave me time to finish.
After a short trip to Texas to visit family at the start of my break, I drove into town to buy some 0.25" tread plate to get on with my build. I know that the material thickness I chose was a little bit of overkill, but I didn't mind the weight that I measured in my SolidWorks model with a mild steel material applied to it.
Once I was satisfied with a very rough cardboard mock-up, I stocked up on some cutting wheels from harbor freight and bought an extra angle grinder (I went through three of the cheap ones in total on this build) and I let the sparks start flyin'!
I do apologize for my lack of picture taking during this build. I regret every second I didn't pull the phone out of my bibs to snap a photo of the next piece that I tack welded into place to better document the process.
I cut the chain off that I was using to move the bumper around with my engine hoist, and called on my pretty lady again to add the finishing touches. She even bought the license plate as a surprise for me to top it all off (sorry to the red fans).
ALSO, don't be fooled by the angle of all of my pictures. I did in fact cut plates to fill the gap and follow the front end profile of the truck from the top of the pipe all the way around from side to side. I built these plates to fit just under the headlights and fenders, leaving no gap between the bumper and truck when looking down from above. Also, for the grill, I tapered both sides all the way in to the middle so they follow just along the contour of the grill. My methods might not be perfect, but I like to have something that will be on my truck for a long while look good!
You know what they say, hindsight 20/20. There are so many things that I will do different on my next bumper project like this. To name a few....
  1. Create a more accurate computer model with true dimensions and drawings to follow during the build
  2. Run FEA (Finite Element Analysis) in Solidworks with some calculated forces to examine different material thickness selection
  3. Redesign much better mounts and mounting locations
  4. Lower the pipe profile 3/4 - 1" lower
  5. Cut all pieces at once per my part drawings and tack one by one to the truck (like a true manufacturing process). This would have saved me a lot of time
  6. Remember that what gets cut on the backside of a piece of tread plate is not going to be oriented the same way when you flip it around to the side you want showing!
The good news is that I will soon be building a rear bumper from the same material as well, and I am already planning the build/documentation process out to make sure that I have more to show for my work!
Thanks for reading, hope everyone enjoys! I would love to hear any inputs or feedback in regard to what everyone thinks, good or bad! A man's worst critic is the one he wants to hear from to become better at whatever it is he does.
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
I like the plate work. The tubing sticks out wide as hell. Dont park in a compact stall! Are you going to cut air holes and add some lights, shackle mounts? You have so much room for a winch. Dont forget to add crush sleeves for the lower frame mounts because when you draw the bolts tight the frame will give and crush. Try adding a support from the corner for support. Just in case you bump something on the corner.
ryanship
Feb 23, 2017
9
Sadly many of the photos don't show. Good work though
Do they show now? I spent some time after my initial post to figure out how to display actual images instead of the shareable link shutterfly was giving me for them.
ryanship
Feb 23, 2017
9
Yessir, that was my goal with the tubing to bring it around either side. Believe it or not, I have taken it through two separate automatic washes (given permission from the workers) to see if would fit! I have been back and forth on a decision to cut holes and run lights, and if I ever make up my mind on what to do I will be sure to throw it up in here. The shackle mounts are hard to see in the last picture, especially after someone stole my shackles here in the city where I go to school. They are not suitable for the size of the truck and even though I made multiple hot passes on them when I burned them in, they would most likely fail if my truck needed a serious tug from the front. This is something I plan to address hopefully at the same time I build my rear bumper. Don't think I will add a winch, and an initial idea that I did not have time to fulfill was side mounts for the tubing that extends around each side. Thanks for your comment! Love hearing what people think.
ryanship
Feb 23, 2017
9
I can see them all. Any idea what it weighs?
My SolidWorks model with an applied material of 1023 Carbon Steel weighs in right at 246. 60 lbs. I think this is on the heavy side, and I would likely bet that it is closer to the ballpark of 200-225 lbs.
I measured the ride height different of the truck, and it dropped half an inch with bumper on vs. bumper off.
5,828
absolutely not my cup and tea and i dont have much nice to say about it BUT
i respect the effort and work you put into it. looks like your fab work was done well :cool:
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
Yeah when i built my bumper i had to fillet the shit out of the shackle mounts to get heat deep into the 1" mounts. Dont get me wrong its also not my cup of tea but it is nice and building my bumper i can relate to your hard work ad stress. Like i said add supports from the corners to the mounts to triangulate it so you get strength. cut holes for vents, lights and winch. You mught be surprised on how much weight you save.
http://www.duramaxdiesels.com/forum/showthread.php?t=74115&page=2
ryanship
Feb 23, 2017
9
I really appreciate it! I have got to say from looking at your truck pics that those dyno pulls are impressive. Good lucking truck too man.
ryanship
Feb 23, 2017
9
Its so awesome to see the different style that you built for your truck. Looks great man, and something like your shackle mounts are exactly what I'm looking to replace mine with. Also have been thinking all today about cutting holes for air and lights, as well as the side mounts. Makes it hard to focus in class.
