Freighttrain Photo
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
did you gain more wieght with the lift?....secound make some custom mud flaps that taper away from the truck:):):) that will help form pyling up all that sand and muck from the tires and the truck.....it helps trust me....3rd can you shave anymore wieght off the truck and hang anymore on the front? 4th mean as fuck looking and is the background on my computer
OH yeah :):) i would run like 15psi on that track in the front....and maybe 35 or less if i could see the log of rpm's and wheel speed...not to be so judge mental steve just tryin to help out alittle:) Ec out
02freighttrain
Team Salad Bartender
Aug 13, 2006
911
sootville, Fl
Thanks Eric, The lift added about 200lbs. The mud flap thing is something we are tossing around and in the photo the truck had 21 lbs in the rear and 18 in the front:eek:. I would run them lower but I'm worried about spinning them on the rims. i saw a truck do it one night. I hang 800 on the front, 100 in the cab and 140 in the bed. We are playing with moving the weight around. Amazing how much effect it has. Thanks for the suggestions.
c_murray7313
Addicted to HORSEPOWER!!!
Apr 2, 2007
145
41
Ocean City, Maryland
thats sweet looking rig you got freighttrain. maybe i can get hooked up with you guys next time im down your way and you can give some newbie pointers for someone who has never pulled before. have a good one and merry christmas.
Chris
duramaxin14
Just Keeping Up
May 25, 2007
912
Wauchula fl
Steve i wonder who's truck that could have been.:D
Chris come on down here hook to a sled men it will be fun i will give u the tips now hook to sled lock i 4X4 and punch it see how far is will go:rofl:
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Cool Steve....I know the mud flaps will look gay as hell but you will benefit alot more than i would from them with all the loose dirt... That was alittle trick i picked up from a old man thats pulled pro stock gas 4*4's for over 40 years...Wow thats some LOW tire pressure...Im really shocked you havent spun them on the rims already...It must be from all the tire spin...I bet if you hook up really hard youll be able to spin them on the rim with that much tire psi...The gasser trash guys always say never under 40psi in the rear becuase it usually induses wheel hop but we all know a dmax hardly EVER wheel hops so i have ran much lower at around 30
02freighttrain
Aug 13, 2006
911
sootville, Fl
What lift did you go with?
Tuff Country 4".
Nice parts and a fairly easy install. The Tie-rods and CV's are negative towards the diff.
Durring the pull it look's like they are Horizontal, with no off angle crap. TNR has the same lift and it is working good for him too. The IFS on our trucks can be a nightmare in a sled pull situation. This lift eliminates a lot of the issues.
