What are some signs of an FPR going out? Is desired frp higher than measured frp? Or is it the other way around? Typically how much difference is allowed between desired and actual frp?
I had two separate issue. First was the solenoid on the rail, it wasn't closing completely allows fuel to run back to the tank causing low frp. Second the housing for the fuel filter, it went bad would not hold pressure.
