LB7: FPR and Glow Plugs
workin' diesel
factory tuned
Nov 13, 2010
630
Coalhust, AB Canada
I have a few questions. One how do I know my FPR is bad? Some talk about a lope at idle. Mine seems to have a real slight one. Can someone check that with a Soleus? Also my glow plugs. Truck does not want to start when the temps get into the low single digits. Never used to be that bad. In fact I never have plugged it in as much as I have this winter. If they were bad would the truck throw a code? Or is there really no way to know other than startup performance? Just looking into a few things. Might have myself some projects this summer.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
The lb7's don't throw a GP code. You would have to ohm test them to know. Or pull them and bench test them. I ohm tested mine and had two that were wicked bad.
As far as FPR goes... Search bottle test on here I believe I remember seeing an amazing writeup on it once before.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
How do you ohm test them?
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
I used my dvom and hooked one lead to where the GP bar bolts to and the other lead to battery ground and read the ohm reading with the GP still in the block. I've been told anything over 1ohm is out of spec.
I had two that were 2.2 ohms so I replaced them and since then it starts much better.
Fandango
Aug 7, 2013
54
Mefis
My LB7 throws a Glow Plug code, P0380.
Is that just the CA version, since the Federal ones have the bussbar?
workin' diesel
factory tuned
Nov 13, 2010
630
Coalhust, AB Canada
Did you replace only the bad ones or did you just replace them all?
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
I only replaced the two bad ones and it fixed my hard start below 0 I was having. They were $26 each at the dealer with my discount :(
3,727
296
Usually you just replace the bad ones. It isn't like injectors where they are a pain to get to. Might as well just do one at a time. I've been doing one at a time for years, on several trucks, with no ill effects.
workin' diesel
factory tuned
Nov 13, 2010
630
Coalhust, AB Canada
What brand are the ones from the dealer? The parts store has bosch and a few other brands. Could also get AC delco from Rock auto. I will likely have to replace those connecting straps since mine are super rusty and frail looking.
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
AC Delco from the dealer.
I went and asked my parts guy to look em up again. The ones I got were Bosch from a GM dealer. so maybe they carry both?
the straps are about 30 bucks a piece but i bet a member has a set you could grab pretty cheap i bet.
