Found out where my other 2 MPG's went
Dirtymaxx03
3,109
Last couple tanks i noticed my fuel mileage was down a couple mpg's. Well i got to poking around and found out why
the black thing im pointing to that the red wire plugs into, leaks like a siv.
Question is, do i need a whole new filter housing now? Or is there a fix?
13,736
806
Is it coming out through it or around it? If it is coming out around it, it is the o-ring that seals it and can be fixed with a filter head rebuild kit.
Dirtymaxx03
3,109
Its coming out from around the bottom of it. Not up through the middle out the top. So a rebuild kit will do it?
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
That's the fuel heater power pass through. You will have to pull the filter head off and rebuild it to reseal it. Also make sure and replace the o-ring under the primer pump as it is probably hard and getting ready to leak.
Dirtymaxx03
3,109
Just bought an MA rebuild kit and a WIF plug :thumb:
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
Shouldnt be any codes. Just un plud the water sensor and it will no longer send a light for water. Im lookin at deleting mine here real soon once im do for a filter change. Dont need the factory since my lift pump has it.
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
I took mine off (since there is no room over there) and now run the AD filters, and an inline cat filter (based on the writeup by one of the guys on here) works great.
Dirtymaxx03
3,109
there seems to be a bit of confusion. I thought yall were deleting the fuel heater cord plug thing. Im not going to delete the housing cause my fass has no filters.
dmaxman06
May 25, 2011
493
morenci az
there easy to rebuild i have used the madjack raceing oring kits i have rebuilt 2 of them myself one on my lb7 and i just did a buddys lb7 dually that has over 250k on it and it and it was leaking in the same place as urs is
Dirtymaxx03
3,109
already ordered a kit, now i just have to enjoy this shitty fuel leak till it comes in
