Found My Oil Leak
Bluedodge
Jul 31, 2014
32
I found the really bad oil leak, I am having on the new motor build. It is coming from the passenger side lower valve cover gasket. Gasket is brand new, any thoughts to this. Should I loosen the valve cover and try a re-torque and feeler gauge around it to make sure it dosen't leak or replace the gasket with another new one?
Bluedodge
Jul 31, 2014
32
I knew it would come to that, I was just hoping somebody had got lucky with a re torque.
Bluedodge
Jul 31, 2014
32
Gasket got tore somehow on assembly, new gasket going in and put it back together tomorrow. When I took it apart it was in the groove. Guess it's just one of those things that happen.
Bluedodge
Jul 31, 2014
32
Exactly, my first thought before I got to really inspecting it was, the motor has to come out to reseal the upper oil pan. My next motor, I'll rig up air on a regulator to check seal on the oil system and coolant system, while it's on the stand.
