Meth: Found my meth tank
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Finally found a meth tank that will fit where I want it.
8x16x54 = 27 gallon capacity. Going to put it inbetween the 115 gallon fuel tank and the 5th wheel frame rails. And Tee it into the 7 gallon tank with valves on both so if I want a stronger/weaker mix they can be used seperatly
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Are you still using distilled water and mixing in your own meth? how is it going with your oil?
Yes, I use distilled water and got the meth by the 55 gallon drum to mix it myself.
Last oil analysis was still no water in the oil and no excessive minerals. Goin to do another oil sample when I hit 300,000
Been running h20/meth for over 140,000 miles now
9,903
149
I like the idea of the bigger fill hole. That tiny little POS that came with my Labonte 12gal tank sux. Takes a month of sundays to fill.
DMax518
Dec 30, 2010
5
Colorado
I am interested in snow performances water/meth kit. Does this really lower egts by 200-250degrees? I was interested in this simple for the lower egts, but have heard that water/meth doesnt really give the drop in egts they claim. Thanks for the help.
