Fog Lights
taysdmax
USCG
May 28, 2010
42
Cali-NC
I have an 01 and my fog lights dont work ive checked everything I can think of Fuses, relays, bulbs and the actual switch in the dash and nothing works does anyone have any ideas or maybe the same problem and hopefully fixed it??:confused:
9,903
149
Does the relay click when you turn the fog light switch on?
If so, check to see if you actually have power to the plug at the light and then start working your way back to the relay in the fuse box.
taysdmax
USCG
May 28, 2010
42
Cali-NC
I havent checked to see if it clicks yet but the little light on the dash for my fog lights doesnt come on if that helps at all??
rick67
Jan 20, 2010
50
Indiana
Swap the fog lamp relay for another relay with the same part number [ie; horn relay. ]see if your lights work. See if the circuit works that you swapped the relay into. If you have a scan tool available that will read bcm data, check for input from switch. Can't help much more without a wiring diagram.
taysdmax
USCG
May 28, 2010
42
Cali-NC
Bulbs are brand new...I dont think there is power going to the switch but idk what it could be ive checked fuses and relays where do you check the grounds?
