need to buy some bolts to be able to mount engine onto engine stand. what size bolts are they thread wise?
I built mine on a stand held from the rear cover. Just make sure you get at least 4 bolts in before you let the stand hold any weight, and ensure they all have good thread engagement.
You can rip the threads out of the rear cover if you don't use enough bolts to hold the weight, or the bolts aren't getting equal weight... so be careful, but it can be done just fine.
Mine held the weight of the long block (heads, turbo, everything) with 4 high quality bolts spaced fairly evenly around the rear cover. But I wouldn't trust it to hold the full weight while you are prying on something to loosen/tighten it, so additional support is recommended in that case. I would use a engine hoist to support the front of the motor when I had to reef on something (like head bolts).
I put the flywheel on at the end, since I was building the engine from parts. But you should be able to put a complete engine with flywheel on a stand.Sorry to bring up an old post Dave but when you put your engine on a stand did you have the flywheel there or did you put the flywheel after everything? thank you
