Ok so my truck just rolled 80,000 as i got it and now i want to do things to it programmer exhaust egr delete. Should i change the fluid now or wait? And if i should is there a drain plug on the T converter?
If you have the coin just get the trams built. There is a do it yourself method called the hoot flush. Go over to diesel place .com and search for it. If you're going to keep it stock I would suggest refilling it with transynd
