I plan to drain the fluid and install a fresh spin on. I am switching to Amsoil Torque Drive. I don't have the stones to do the Hoot method. My plan is to drain the pan and change the spin on, then add 7.5 qts of Amsoil. Then drive it around for a bit then repeat, along with a fresh spin on again. I am hoping this will get me a pretty good mix in the trans. How long should I drive it between changes? Any tips or tricks, I have never fussed with the trans before so I'm a little worried. Thanks.
