LLY: Fluctuating oil pressure LLY
tim_Lly
Oct 2, 2016
5
I have an 05 duramax and I noticed the other day the oil pressure fluctuates on acceleration it gets as low as 21psi and midrange or 3/4 of the way on the gauge is this a problem ? Thanks!
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Could be just an electrical issue. Or could be early signs of crank failure.
tim_Lly
Oct 2, 2016
5
Yeah the chip reads the same cts 2 edge juice with attitude
Awenta
4,090
CT
Verify with a mechanical gauge
mebob2001
Riverview, new brunswick
That's 100% normal. When cold it will be around 80 psi when accelerating. When it's up to full temp 19 to 22 is normal depending on oil temp.
As for it changing when rpms go up. That's to be expecting oil pump is moving faster so it will flow more oil. No need to check anything unless it goes bellow 15
Sent from my SGH-I337M using Tapatalk
tim_Lly
Oct 2, 2016
5
Awesome thank you man
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,198
362
At Da Beach
Yep, totally normal. Don't worry about it...
