I'm looking for a simple internal flow simulation software that I can use to help design better flowing parts. Anyone have any ideas?
STAR-CCM+ is a flow simulation software as well.
I use SW at work, its not bad but without real life flow data its not that accurate.
We have slowly got enough real data from the lab to correlate how we set up FEA stuff for real results. 51k ft up in the air is hard to do flow wise.
Star CCM is another good tool. It's relatively easy to learn, but won't be as powerful as a more expensive tool. If you are looking for a tool to model static flow (i.e. steady state), Solidworks will be fine (if you're looking to improve the flow of your manifolds, pedestals, etc.). If you want to model how each exhaust pulse influences the next, you probably want a more sophisticated tool.
If you want a really crazy model (flow as temperature increases while being acted on by each exhaust pulse), you'll need a multiphysics program.
I've found that Solidworks' FEA is very accurate. Their CFD, on the other hand, leaves much to be desired. I tend to treat Solidworks' CFD tools as a quick sanity check before moving on to a more powerful analysis tool.
For my own curiosity, what do you work on that sees 51k feet? The flow simulations do get complicated when you cross from subsonic to mach.
I'm looking to start out very simple.
For example..
I'd like to play with the radius of bends and see the differences.
I'd also like to see what a sharp protruding surface at a joint does to airflow.
I'd like to see how the airflow slows or speeds up as the size of the passage increases and decreases.
Stuff like this. Then I will work my way up.
For example..
So to use your curve metaphor, you want something like a decreasing radius curve?IIRC, the "perfect" curve tries to keep the lateral acceleration constant. Since the air is accelerating linearly when the valve opens, it is picking up speed, which alters the lateral acceleration. Any time you accelerate anything, it consumes power, so the trick is to keep the losses at a minimum.
Picture driving into a corner while your foot is on the gas. If the corner is straight radius, you will scrub hard on entry due to instantly going into max lateral acceleration. Then you will hold the lateral acceleration, then it goes away instantly. You want a cubic curve that brings the acceleration up while the speed is increasing, then for it to relax.
The speed at which the air is accelerating governs the perfect shape. Constant speed airflow will generate a curve that is a different shape.
This is how some heads and exhaust systems show good flow numbers yet pieces with lower bench flow make more HP.
Look closely at a modern turbocharger blade. There are no true radii on either the blade or even the hub. And certainly the snail. They are designed for a certain acceleration. It's why they suck when the airspeed is not in the target range.
Most of my experience is from 30 years ago, as it pertained to 2 stroke racing engines.
