Mike i havent broken this one yet but ive been thinking if i do would it be better to go back with 2 instead of 1?? And if we cant do that then why
do you use a ats converter?
You are going to have to do things properly as designed by the engineers that designed this shit or live with your failures. Seat of the pants technology does not work anymore. If you are going to attempt to improve on what these engineers have done, you must use what they gave you as a base and improve on that. You are not educated enough to out think these guys. Yet.
Go to school, improve your spelling so that you can properly get your thoughts across in writing. Try and see what the engineer was trying to do with whatever design you are looking at and then see how you can take that design and make it better. Never think that you know better untill the time comes, if ever, that you really do. Then you can brag.
I know you will probley say get billit.
You should only run the billet flexplate sold by ATS with an ATS Torque Converter. Mix and Match has caused problems for several people running both SC and PI converters.
Mike i am just trying to think outside the box. There are plenty of people having flexplate problems and no one seems to want to cure them. I have broken 3 so far by my self and its getting old to keep pulling the tranny out. I follow all steps and torque them down how they should be. Ive ran 4 bolts i ran 6 bolts and ive ran 8 bolts. To be honest when i ran 4 bolts the flexplate has lastested alot longer. Can u try to come up with a cure for us guys that keep breaking them. I know you will probley say get billit. But i dont wanna start breaking other hard parts. A flex plate needs to flex if its solid what eles will let go?
I think that 2WD couled cause more stress on the trans, TC and flex plate, especially since you don't have low and are relying on the TC to take the abuse of getting the weight moving. Also Travis may be onto something with the TC causing the problems. But most of all as Mike said what you are saying and what you are saying you are doing are not lining up. I've heard of TC bolts coming loose and even having a few come out of a truck that made low 13 second passes and had no flexplate problems. I also know of trucks with 700+hp running stock flexplates with no problems. I have cut 1.69 60' times launching in 2nd with no problems. Do the stuff to the book's specs (or even better Mike's specs the few times they differ from the book). Billet plates are made to meet SFI specs for the RPMs you turn. At your power level I know you aren't turning RPMs that need one and shouldn't be breaking flex plates.
2WD causes less stress and that is a fact. Reread your post and think about what is not happeneing in a 2WD as compared to a 4X4 as far as stress goes.
Why not give factory specs a try instead of your own stupid ideas? You have more problems with anything you do than 20 truck owners put together. I am really tired of your problems because you choose to do it your way and your ideas do not work. You posted that you tried 8 converter bolts when there are only 6 holes.WTF You posted you torqued a converter bolt 130lb.BS It would have snapped. It didn't happen. You screwed it up. I have 1000 hp trucks out there with no flex plate problems and you have a piss ant 2WD, with less drivetrain stress breaking flexplates. You need discipline and education. You have neither and you need it.
I did not mean to blast you here and am willing to help you, but your ways are wrong. With your work habits, you would not last 5 minutes in my shop.
Either you will hate my guts for this or you will make a change. I don't waste my time with long posts unless I think I can help.
It has been posted multiple times. Look in the past 2 or 3 threads you've started about breaking your flex plate; it's in there. I even posted the converter bolt torque specs in your 5 converter bolt thread.Mike then tell me what i should do correct specs if u want me go in a star pattern what ever i will do it tommorw and report back if i have a problem I will start by puttig all the bolts in the flywheel and flexplate. Tell me torque specs and everything eles
Why don't you follow the correct torquing procedures? (FYI, you can pick up a torque angle meter from Auto Zone for $10)Yes ben and it was torque down with a torque wrench. I also went around it 5 times to be sure they where at the right torque. I torqued them to 100 foot pounds this time rather then 8 like i think they called for. And went in a star pattern. My converter bolts is my biggest concern right now. I think when i get a smoother shift my flex plate will be fine
For one thing you need to replace those 14mm hex bolt that hold the flex plate on and tq is very high on those bolts
Flywheel Bolt - Angular Tightening Method
1st Step 58 lb ft
2nd Step 60 degrees
3rd Step 60 degrees
Kurt Mike said to do it by GM specs We have posted this many many time really hard to help you, Who is Niko person that gave you specs I guess the one's I posted from the good old General is not good enough.
