Help: flexalite fan help
ZeroGravity58
1,401
51
Maryland
Well id like to thank flexalite for there wonderful parts. I almost got stranded in New Jersey because there $10 fuse/breaker decieded it would completely melt down on me. I was stuck in traffic and noticed my truck started overheating. Pulled over and popped the hood and smoke was rolling. That little thing melted and the studs and wires were just hanging there. So of course i had to rig it up so i could finish my 1.5 hour ride home :mad: is there anything else i could use?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
JMO, but I dont really see the point ofputting e-fans on a dmax... IMHO the maybe 1 mpg in savings isnt worth problems like these (and not being able to tow heavy)
I have haerd of this problem with flex-a-lite's kit...I think they have an updated part??
ben
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
You have the old style controller. Contact Flexalite to get the new style otherwise you will keep smokin them. My buddy went thru six of them before he got the new style and ever since he has been golden. His truck gets hot when hes pullin a heavy load tho........
ZeroGravity58
1,401
51
Maryland
ben
Well to be honest i dont tow at all my truck doesnt even have a hitch. It has no hitch and a has a rollpan on the back. I didnt buy this to tow heavy with. I bought this to race and have fun with. The fans work great. Truck never sees over 195.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
See if you can get the updated switch. iirc the old style switch has been known even to catch fire :(
Same thing happened to Casper a couple years ago.
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
I think they would work great for racing on the track, i get tired of my clutch fan comin on. We cant run the elec fans up here at 6000ft tho cause there is not enough air. His truck hits 300 degrees and has to pull over if hes pullin anything. We contacted Flexalite about this and they told him to put a pusher fan in front since we were at such high altitude. I want them for my truck but i dont want to have to pull over or get stranded.
ZeroGravity58
1,401
51
Maryland
whats get upgraded? the fuse/breaker that burned up on me or the actually fan controller? i will have to get ahold of flexalite. it wasnt a problem i just unhooked it up right to the alt for the ride home but i dont want it happening again. i havent pulled anything with these fans but i have had the bed loaded up. they have never missed a beat and the AC works alot better with the electric fans.
Killerbee
Got Honey?
notwithstanding your opening post?
This is the most expensive way to reduce the load capacity (and hence value) of the truck.:cool2: But I guess everyone has a different take. What I see...if they die, you just have another air flow restriction, that's me.
Try locating the important stuff where there isn't so much heat. Just a thought.
Jun 28, 2007
3,259
NE Pa
Do they give you the updated part for free? How can such a big company make such a huge error? Chossing a big enough relay and other parts is really pretty simple stuff if you sit down and do the math:confused:
I know it doesnt help with d-max's but I always thought most aftermarket fans were junk and whenever I put one on a car I always used an OEM fan for a different car from the junk yard or dealer....ford tarus fans work really well on cars:rolleyes:
Jun 28, 2007
3,259
NE Pa
Couldn't be that tough.....they got it fixed now....right?
I agree but a little thing called overkill goes a long way....but big company's don't like this because it cuts into their profit. There are plenty of relays ou there that are up to the task, but they cost more. It's just a shame that things need to go soo wrong for them to step up to the plate and do it right.
"Theres never enough time to do it right....but theres always time to do it over again!"
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
taurus fans work awesome. I run one on my offroad buggy. Moves a ton of air and cost me 10 dollars, with the fancy controller.
Wouldnt move enough air for a dmax tho
ZeroGravity58
1,401
51
Maryland
i still have the factory fan in the garage. if i ever had to tow anything or a sold the truck i would put it back to stock which would probally only take about 1/2 hour to switch it all back. Its pretty simple.
ZeroGravity58
1,401
51
Maryland
right but when you drive around the city with the windows down you really get tired of hearing the stock fan. so guess what the stock fan got taken out.
ZeroGravity58
1,401
51
Maryland
my main reason for the electric fans was so i did not have to hear the clutch fan. the HP you gain if any is nice also but the stock fan sucked. it is loud during the summer and during the winter id have to drive 10 minutes before the darn thing would unlock.
