Back when I built the trans that's currently in my truck (25k ago), it was flawless with the 5-speed VB. Shifted great. I had to put the 6-speed VB back in a while back so I could put the reverse pipe back in the original 5-speed trans and sell it. Once I put the 6-Speed VB back in, it started getting dumb. For the most part, it still shifted good. The problems where in the 2-3 & 4-5 shifts. It was learning STUPID TAPs values (like 7psi) and would flair the shifts pretty bad. Now that I've converted my truck to the LBZ ECM & TCM, it's MUCH better all around, but the 2-3 & 4-5 still aren't great. They don't flair like they did with the 5-speed TCM, but there seems to be a little flair on occasion. The TCM's learning "normal" TAPS values.
Since the one thing in common between the 2-3 & 4-5 shifts is C3's are applying for both, I'm guessing that the C3's may have gotten burnt or glazed from the 5-speed TCM's retardedness.
Anyone have any other thoughts? If Mike as anything "New & Improved", I'll probably look to pull & refresh it in the fall.
