Ever since I installed my lift pump years ago I've always battled with gelling issues at the pump itself. Even with double and triple batches of additive installed the fuel still gells up just enough to clog the little tiny inlet screen into my PPE pump. So I finally got creative and rigged up a few little heaters for the pump and the inlet pipe.
I got some 12 volt heater strips HERE. When completely heated up they put out some decent heat. Enough to where you can only hold them for a few seconds. But not enough that melting is going to be an issue.
The heating strips:
Here's my original setup:
Installing the heat tape:
Wrapping the lines in insulation:
I wired the heaters up to a dash switch for now as I want to physically see if they're going to help. Unfortunetly it was 60°F today so it may be a while till I can prove the effectiveness :rofl:
The heating strips:
