First time dyno run...
StuntHeavy
Jun 26, 2010
Hey all,
About to hopefully run the truck on a dyno for the first time on the 10th. Couple questions:
Any particular things I should be aware of that maybe a typical dyno operator may not mention?
EDIT: Just been informed that it's potentially an inertia dyno they are bringing..... I'm running stock turbocharger....thoughts on this?
Running EFI Live, so what PID's do you all log while running?
Running a Duramaxtuner.com max effort tune on a dsp5 switch, LB7, ppe boost valve, modded airbox with k&N, intake heater deleted, Pro-Fab intake horn, 4" downpipe, straight into 6.5" stacks, Airdog 165, egt and boost gauges, and finally suncoast gmax-5 kit and ML converter currently in the mail, waiting to go in.
Goal is 500whp/1000 ft lbs tq. Think the truck will be there? Should I consider water/meth injection to help it along?
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Hey all,
Shouldn't be too far off. I saw just under 500 with a tune, lift pump and exhaust. That was a 4th gear run for me using a tune that was also on a dsp5 program. Not sure what PID's you wanna log though, not my forte... :eek:
05chevy
1,086
I made 527 off of.diesel addictions mac effort tune. 5th gear run and Dustin sent my pid duramax_imperial I think there's something on the end but I believe the default on ur efi live with work.for ur lb7 I need a different for the vgt Turbo vane position but look for duramax- imperial that should work
