Finally ran this truck.
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
I finally was able to my Dmax at the track. Now since this is my DD and parts are not cheap I started out no boost launch and roll in to it a bit well seeing a 16.111 pissed me off. So **** that put in 4 wheel and bring her to 15 psi was good till the 1-2 shift and it bogs down had to let off and get back on it get it going but still ran a 14.504. Played with a few things and made the next pass at 14.449 still boging but not as bad. Last pass was my best R/T of .233 but boged real bad and ran a 14.515.
Sad thing was I was one of the fastest DD diesel trucks there was not that there was a lot of us maybe 10 or so Diesels there and 3-4 were not SL with all slicks and 2 bottles of NOS. No real good ones. We need more D-maxs there the Dogdes had all top 3 over all from what I saw one with a 11.337.
So where are you guys I know lots of you are near Castrol Raceway.
Also I need to get a EGR Blocker lol stupid thing keep popping and maybe some W/M as the EGT were a bit high as they set P0546 and P2033 lol
MadMaxx
9,905
151
My first trip to the track I ran a 15.7 stock, next time a month later I ran a 14.3 with an ally jr and tuning. Give it time-faster passes will come.:D
I may have a blocker plate I can give you soon. You should throw an ally jr. in that trans ASAP as it will help your shifting and maybe help you hold a little more power. Also anything you can do to help it breathe will definetly drop egt's as well. Pull the P/S headlight, remove the heater grid from the intake, block that egr off, and get a downpipe. Those things alone should drop your egt's a couple hundred degrees.
9,905
151
Oh yeah and a lift pump, FPRV shim kit, and a set of tie rod sleeves or replace the stockers with Cognito's HD tie rods will help keep your front end together on boosted launches in 4wd.
I know, like you said parts are expensive but you will totally get out of it what you put into as far as the fun factor goes-unlike the shiney things for your truck that you can waste money on!:D
TYREBOYZ_DEMAXIN
The Tire Frier
Jun 13, 2007
250
Barnesville OH
who does your tuning if i may ask?
sounds like GM sorry excuse of traction control is kicking in and bogging you out..i got so sick of our LBZ doing that!
i would def see about doing lift pump,shim kit,Transgo JR and adjusting PSI in the tires!
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Well I was saving for a Mike L trans and hoping to drive to him in the spring as work is slow right now so I need to save. If you have a LMM blocker plate that would be sweet but I may be looking at getting rid of all the EGR crap. Yes downpipe is on my list of things I need ASAP. Just looked at my air filter today and yep that thing was packed with crap might be time for a S&B too. Your from AB how well does the truck start in -45 C with out the intake heater?
Ya I had a shim kit on order but never came in so time to get one from one of the vendors on here. Will be making some sleeves at work as I dont want to get the Cognito's HD till I do a lift down the road. I might make a center link too if I can find some good stock SS at work kicking around.
Bogging? From spinning then catching traction?? Maybe try launchin in 2nd?
Not spinning as I was in 4x4 but the traction control or torque management crap kicking in.
As I have not done much tuning for the track I ran a Race tune from Nick P. Lift pump is going in as soon as I finish setting up the new fuel tank and pickup I know bigger tank will slow me down but I need it for the long trips I make. Had the Tires in the rear ay 40 PSI but 50 in the front as they are still the stock ones but about 10% tire tread in the rear lol.
I saw your truck run yesterday. Looked pretty good, I didn't run mine.
Well next time wonder over to me and say hi so I know who you are lol.
PS: Why did you not run yours? I was put up next to a 90% stock 06 LLY he had a DOC delete and CAI that was it he ran a 17.178 and he was a 2wd.
MadMaxx
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
Next time I will have to wonder over and say hi. I checked your garage this morning and saw that it was you. I have some parts kicking around that I want to put on the truck before I go to the track, I'm a little nervous about it actually. But every time I go it make me want to race more and more, so it's gonna happen. :)
9,905
151
I will let you know about the heater-I am going to get a delete kit from MMLMM if he ever gets them in. I like my S&B and I think it works well on our trucks. As far as shim kits, I just put a couple of washers in mine and it works fine. They are like 10mm or something IIRC. That torque management crap can be tuned out. I had the same issues with my LBZ-my face would almost hit the steering wheel on shifts!!:rofl:
Dan, you need to get that truck on the track!!:D
9,905
151
Nope, thanks to a mexi-californian, it shifts reasonably good for a beat up trans with a junkstar converter!:D
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
The washers are 4mm , 2 required. I dont reccomend messing with shimming the FPRV untill necessary ( throwing 0087 codes). Was a real pain in the ass to get seated.
When you get a trans built, up your tune, then you'll need a Shimmed FPRV.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Wendy must be special :eek: I don't run a shims or race valve :confused:
TYREBOYZ_DEMAXIN
The Tire Frier
Jun 13, 2007
250
Barnesville OH
with the tires you have you can safely drop as low as 35PSI in the rears and 45PSI up front,i have done it quite a number of times and it does hook up better for me but i have never ran on a track just a local road strip that i so happen to have the record on and well i have to run it atleast once a week to make sure i am still the fastest in that stretch!:D its a lil over an 1/8 and so far if i squeeze everything i have i get roughly 98-99MPH in that distance and the closest car to me is a 06 GTO with a 6.0L running 90MPH!
if i run normal PSI i drop down several MPH due to traction and not hooking up properly but if i keep low PSI and with the 1057TC that i have i normaly let her rip with 15PSI and 2200-2300RPM's! that is with my RC LLY
i never figured out how to tune that TQR managment bs so i had Rob Coddens do that for me!
