Everything started off with a bad 1056 converter that suncoast fixed under warranty which was very supprising since i had it for a while. Since the convertor was out getting fixed i decided to tear down the trans and check out my stage 4 with 80,000 + miles on it.
Inside i found :
perfect C1's
Trashed C2's
Trashed C3's
Fair C4's
And Great C5's
All the selinoids, pressure switches and front pump were not usable. The inside of the valve body was plugged with trash, the inside of the trans was gold from clutch debris.
I spent 2 weeks cleaning parts on and off i had 4 hours invested in cleaning the valve body and 3 hrs cleaning the stator. everything had to be brushed off i could not get it off with anything but elbow grease. I had to do some filing to remove burrs in planitaries and fix the clutch splines.
While all this is happening i order a Gmax kit and start the install. I learned that you need transgo instructions, ATSG manual and Suncoast instructions to do it correctly. you need the ATSG manual to try to figure out what Suncoast wants you to do and you need the transgo kit to figure out where the extra shit goes
i go to start the install of my new built trans again i start with cleaning all my lines and run in to my first problem the engine radiator is completly plugged and will not allow fluid to flow through it. i make some phone calls advanced has a new one i go get it and fill it with coolant the dam thing is split down the whole side. ok i call napa they also have one i go get it everything looks great in the store. i get it in the truck and the dam transmission cooler quick connects were machined the wrong size and the oring would not fit correctly inside. i took these out and ran down to a friends place and re cut the groove a few thousanths bigger. now everything fits great the truck runs and i think i will be able to sleep better tonight.
So anybody who is going through a hard time just keep cool and everything will be fine in the end. For anybody who is just starting the hotrodding world you may want to seriously consider staying stock. expensive things dont break at stock power and you wont get the go fast bug since now i cant go back to stock it would kill me:happy2::happy2:
Inside i found :
perfect C1's
Trashed C2's
Trashed C3's
Fair C4's
And Great C5's
