FYI, I have had some problems with very high flow engines collapsing K&N filters. Not sure if anyone has had an unexpected surge, where the engine goes flat & boost falls off, but My Camaro was also doing this exact thing. The filter was the largest conical 4" inlet filter they made. It was sucking the pleats together choking off the air.
I then tried Green Filters http://www.greenfilterusa.com/ & they have worked well. The wire mesh they use is a heavier stainless steel, instead of the softer mesh that K&N uses. The filter is much stiffer. Just a thought if anyone is buying filters.
