Depending on which one you put it in. The one higher up toward the side is pre-cooler/filter and would read a little higher than what the bearings are seeing. The one down low (just above the front axle u-joint) is post-cooler/filter. It would be more accurate, but if you tap into one of the bolts in the side of the block (where aftermarket turbos usually tap for oil), that would probably give you the best reading since it is right in the oil galley that feeds the main bearings. I believe it is a 14mm x 1.5 pitch.So it will give an accurate reading on the oil psi in that spot?
Do you know what the thread size is of the oil port in the valley that feeds the stock turbo? Thanks guys
