I recently had a shop install a lift pump (Airdog II 165) and after the install, they said they could not get the filter head to stop leaking and bypassed it instead.
It seems like the general consensus on the forums is "LB7s need all the filtration they can get" and the factory filter should be retained in addition to the filtration from the Airdog.
Has anyone else experienced this and if so, is it recommended to figure out a way to get the leak fixed and run it through the factory filter setup again?
Thanks.
Thanks.
