Injector voltage is different
The communication Style is different. If you use an lb7 FICM in an 05 truck it will not work. If you use an lb7 FICM on an LLY engine in an 01-02 LB7 truck it will work. The LLY FICM will not work on an LLY in an 01-02 Lb7 truck, using the Lb7 controls. The inlet/outlet ports are in different areas as well. The pinout is identicle on both units.
