FICM
toriilo27
Feb 24, 2018
I started my Duramax yesterday started up fine and then it was as loud whining noise it was coming from the ficm on my manifold I turn the truck off I had to disconnect the both batteries so that whining sound slowly came to a stop I reconnected both batteries I got all power but it doesn't even click when I turn the key
Sent from my XT1650 using Tapatalk
toriilo27
Feb 24, 2018
So I put a new ficm in today didn't find any frayed wires in the harness above the manifold put it all back together turn the key not even a click . Could my starter relays be burnt out this is an 03 Duramax lb7
toriilo27
Feb 24, 2018
I replaced the ficm in my 03 Duramax today all the powers there it just would not start not even a click someone suggested that my starter relays might be burnt any ideas
torqued2dmax
646
Brookville, PA
Im sure you checked all your fuses , I think the reason your not getting much response is because the time it took for you to realize where the buzzing burning electrical noise , open the hood , get tools , disconnect both batteries , its just so hard to tell what else might have been damaged ! I would say rather than just throwing parts at it , find a reputable shop like the ones on this site , have it taken there to be properly diagnosed ! Someone might chime in though , but thats what I did before because I know very little !
toriilo27
Feb 24, 2018
I also know very little and I have decided to take it down to one of these shops and get it diagnosed. Someone suggested I might have burned out the starter relays.
toriilo27
Feb 24, 2018
As long as they know Duramaxes , I think you made the right move ! Good luck ! Once I get my new v2 I will be allllll knowing ! LOL !
Turned out when the ficm waiting out in front the starter relays out and burn my starter out also everything is running awesome now thanks guys
gmc502
466
12
can you say that in English.:Dglad its fixed
