Ok so i am showing up a p0206 and p2146 code rough idle and so on , already found my black n yellow wire was exposed at alternator fixed that , but i have also read that people have found a pink wire that rubbed on the bottom of the two connectors on valve cover driver side. Anyone have any Pics of this area and which wire it was ? I have also replaced pigtail on number 6 connector . If i was showing no volts at injector supply voltage on c1 from the ficm and showing good voltge from the ignition voltage supply would this mean anything ? Any help would be greatly appreciated ! Thanks Jeremy
