Fed up pipe
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
How hard is this to do with the engine in the truck?
I found this part number 97223166, LB7 PS pipe for $120 on gmpartsdirect. Any body got one laying around I can buy for cheaper?
paint94979
Beer Nazi
Sep 18, 2006
11,715
I can ship you my stock LLY up pipe and then all you need to do is have the hole welded shut 40$ shipped?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I'll keep that in mind Nick, I'd rather have a LB7 pipe though.
As long as I can get a wrench on the bolts I can probably turn them, thats the part I'm worried about. How tight of a space is it really back there, is there any turning room?
paint94979
Beer Nazi
Sep 18, 2006
11,715
FYI All years pass side up pipe is the same minus the location of the EGR cooler outlet
paint94979
Beer Nazi
Sep 18, 2006
11,715
You will need a good quality 12 pt 12mm socket... I used all 1/2 stuff. You should spray some penetrating oil on them. The lower pass side bolts are easy to get too and break loose. The upper pass side bolts are a little tricky but shouldn't be a problem
kjp800
Aug 6, 2008
525
New Jersey
Its not bad at all to do. Easiest thing is to remove the pass. side fender liner to get the bolts in the manifold. Be sure to soak them and if they feel like they are going to break work them back and forth and they'll come out
paint94979
Beer Nazi
Sep 18, 2006
11,715
oh ya and when you put them back in be sure to use some copper anti seize on the threads. If/when you do a turbo swap you will be happy you did this
