Fastest stock turbo truck
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Just wondering what the fastest runs would be on a stock turbo truck. You can have everything else on the truck built just needs to be stock turbo, fuely only. Anyone dip into the 11's?
SmokeShow
6,818
Lawrenceburg, KY
Good thing you added fuel only cause I think buck went deep 10s or maybe even 9s on stock turbo with an obvious chit ton of nitrous! :D
Dudgy
Runaway
Jun 1, 2010
416
Alberta
I'm sure there's guys that have ran 11's on stock turbo fuel only. i'm getting damn close and thats with stock cp3 and stock nozzles too:thumb:
1,866
See my sig. I think thats it. Not to be a total asshole, but the only reason its not #1 on the list is because of the injectors. I need a reg cab.
Nobody has run an 11 on a stock turbo, fuel only, unless it had dual fuelers and/or much larger injectors on the truck.
I think cwmeaux truck has 11.9x in it stock Turbo/fuel/cp3 fuel only...shed a little weight, and some other stuff and it should rip!
His 11 done with a shot of N2O, wasnt it?
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Track times
I need to take mine back out and dial it in. When I run the 12.15 it still had the roll bar and extra weight that is not in it now. I need to put a light weight driver in it to get a 11. I think Eric may be the person, that would get another 100 out of it.
1,866
Tom what injectors do you have??
30% tips from a shop that rebuilds all the UPS truck injectors for our building. They arent the greatest.
Can I drive?
I thought you retired the reg cab in favor of the dragster? If not, good luck! :thumb:
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Anyone think its possible for me to run an 11 without removing all the seats,floormats, cds, and everything in my glovebox? Lol I only remove the tailgate (half the time) and spare tire when I go.
Sent from my PC36100 using Tapatalk
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
You would have to be around 5700lbs :rofl:
cwmeaux1
303
41
Carlyss, Louisiana
I use a 150 n20 for 11.84, I tried another fuel only pass in Ennis but pulled through break, but still ran a 12.28 with less boost then 12.26 run at same weight, so hopefully we can go faster soon
Dudgy
Runaway
Jun 1, 2010
416
Alberta
My truck is 5700ish lol and the closest i've gotten is 12.18. 5900 raceweight though with me in it. we'll see how it does in 6 weeks. Going back to Mission BC, 6' above sealevel :D In theory it should be faster than last year when i ran my 12.18 down there. Somebody will eventually get a 11sec run out of a stock motor/turbo/cp3/nozzle truck, just a matter of time
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
This thread was about ONLY LIMITED BY STOCK TURBO. Fuel system is up for grabs along with any other mod. People have made 600 on a stock turbo before
