Fastener recomendation for Lund Fender Flares
dzimbric
86
Shallotte, NC
Has anyone else installed Lund Fender Flares on their truck? Mine are fighting me every step of the way and the install is not as easy as shown on the Lund YouTube video. The holes don't line up properly and there are some interferences between the front bumper and the flare.
I'm trying to come up with a solution on how to mount the flares so I don't have to remove them every time I need to remove the liner.
Installing the liners after the flares will solve that problem but I need to use different mounting holes locations for each which brings up the question. What fasteners should I use for the flare? Are rivets OK and how do you keep the fender from rusting if I drill additional holes in the fender lip?
I'm open for suggestions on how to keep from screwing this up.
Thanks in advance
dan
Dozerboy
4,917
496
TX of course
Ya sure you got the right flares? Odd the holes wouldn't line up I would contact Lund before drilling holes in anything. If I did drill it would be in the flare not the fender so rust shouldn't be an issue.
