FASS pump constalty running
gl4787
<-- just sits
Jan 27, 2009
274
WI
So I finished my studs and gaskets job last night and when I hooked my FASS pump back up to the battery when I connected the negative terminal the pump instantly turned on and kept running with my key in my pocket. I ground the pump to the front fender and it works correctly with key on power. Any ideas what I did?
56taskforce
1,081
56
Be sure you are hook to switched power if that checks good check the relay really the only two things it could be.
gl4787
<-- just sits
Jan 27, 2009
274
WI
Yeah, I hooked it up exactly how I had it before I took my truck apart to do the job and it worked exactly how it's supposed to. It works the way I have it hooked up now it's just a little strange that grounding it to the fender would do anything diffrent than grounding it to the battery.
Awenta
4,090
CT
Did you miss or cross a ground somewhere?
Awenta
4,090
CT
I would trace the wires back and make sure everything is good. There shouldn't be a difference.
Maybe you need to add a ground from the battery.
