Fass lift pump questions concerning gauges and stock filter
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
I put in a fass 150 and I'm still running a filter in the stock location. I'm running a cat filter in the stock location. Should I keep running one there? Will it hurt flow or cause any concerns? Or should I delete it with a fass bowl or just take the filter head out and connect the hoses? Also I put a pressure gauge on the actual lift pump. Does it make a difference having it there or should I put it up top in the engine bay? I know the fass bowl has a port for fuel pressure gauge. Any recommendations guys? I always try to get the best performance and functionality out of all the work I do. Thanks!
2005 Chevy LLY
Extended cab short bed 4x4
Sinister EGR delete kit
S&B turbo mouth piece
Sinister intake tube
AEM CAI
PVC reroute
4inch straight pipe
Edge CTS juice with attitude plus hot tuning
WI Huck
Where does the time go?
Feb 8, 2012
137
It will not hurt anything by leaving the Cat filter in the stock location. The FASS pump will push through it just fine. Think of it as additional insurance. Putting the fuel PSI sensor on the FASS pump is fine also. It will let you know if the pump is working or not.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Ok thanks for the ibfo
05 Chevy LLY
-Extended cab short bed 4x4
-Sinister EGR delete kit
-S&B turbo mouth piece
-Sinister intake tube
-AEM CAI
-PVC reroute
-4inch straight pipe
-Edge CTS juice with attitude plus hot tuning
-PPE race plug and ported FR fitting
-33's
