Fass High pressure Pump
djms
Dec 25, 2006
263
Houston tx area
I got a high pressure Fass pump with some stuff that I bought from a guy I thought it was just a pump without the filter. Turns out that is not the case. Can I run this on a Lbz instead of a lift pump? And if so where do connect to, I was told it goes under the hood somewhere, fuel rail? CP3? I'm lost. Thanks
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
That is a lift pump
i would probably put it on the frame somewhere ,It ties into the 12mm fuel line under the truck to precharge the cp3
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
PS If you know Dustin at diesel addiction i would swing by and im sure he would be happy to show you how it works:)
scramHD
112
Tx / MS / AL / MEX / FL
try a search, or in the diy section
try fass website for install instructions and you should check your parts list vs what comes in the box
have you connected a power supply to see if pump even runs?
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
I think this is the one where he is missing half the lift pump.
Post pic of said pump.
I think you should contact seller and get refund. You are missing half you pump if it is the one I am thinking about. you cannot make it work....
djms
Dec 25, 2006
263
Houston tx area
I don't have a picture of it but the guy said that this one went under the hood on a wide open throttle switch and he was running this along with the other fass setup on the fuel rail. I thought he said this pump was capable of like 100 psi? I don't know if there is any truth to that though.
