Well I got the red power wire into the harness, the black one was tough going in at about half way... Yes it was going in the correct way. Tryed to pull it back out and the wire became unsoldiered... I went ahead and pushed the pin al the way down (i think) cus it wouldnt come back out..
So the wire is just hangin there and may fall out?? what will happen if that ground falls out or isnt seated right? just my dsp wont work or will the truck have problems?
what are my options guys
EDIT: I think I will be fine, as I was told If that ground won't work, I can just ground the wire somewhere else on the truck (and that was just the best spot to ground it).. So alternator bracket, motormount, framer? where would be the second best place for a ground?
