I have a small leak at the bottom of where the extension housing meets the main case on my Allison. I have looked it and I can not see a crack. fluid is not pouring out, i just noticed a few drops on the floor, have been cleanign and checking it for a couple days, cleaned it last night, let it sit over night and it was wet again.
The front U joint on the driveline is "loose" but no visible play, just not as tight as the rear joint. have a thread on my t case/driveline issue here:
http://www.duramaxdiesels.com/forum/showthread.php?t=76554
Parts on order to repair/balance joints and driveline
From what i have researched, trans HAS to be pulled and stood on end before the housing is removed. I there anything else i need other than a new gasket and possibly(most likely) a new housing?
i have attached pics to show leak
