Extended cab amp / subs
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
can any of you guys post some pictures of how and where you mounted your amps as well as the type of sub boxes you are running.
new truck needs some new sound :D
ChevyTruckGuy78
Twins done Now for trans
Feb 7, 2010
694
Ct.
x2 i wanna add some sound too but don't wanna loose all my in cab storage for when i go to the range
dmaxfireman
Apr 8, 2007
2,329
CT
i'm mainly concerned about mounting the amp behind the rear seat and whether you can self tap screw it right to the rear wall or not (i'm pretty sure its double wall)
ChevyTruckGuy78
Feb 7, 2010
694
Ct.
i seen an enclosure that has the amp mounted to the sub box but it looked like it took all the room under the rear seat
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
When i do mine im going to build a frame to mount the amp to out of 1/2" X 1/2" square tubing the remove the bed and screw through the back wall into the frame and seal the screw heads to avoid any leaks. Just my $0.02
standy
Jun 22, 2009
91
45
Royal Oak, Mi.
There should be some pics of mine in my profile. I mounted the amps to the inside bottom of the back seat. I was concerned about the heat, but I've had zero issues in the last 5 years. I didn't want to screw them into the back cab wall, and I wanted to keep everything easily accessible, so this setup has worked well for me.
ChevyTruckGuy78
Feb 7, 2010
694
Ct.
yea unfortunatly i cant do that i store my guns under the back seat which dosent leave me any place for subs unless i were to do something in the back doors but that would be way too much work to make work and look nice for my app
howie
Dec 26, 2009
167
Sawmills,NC
here is a few pics of my box has 2 12inch subs and a holder for the amp
picture.php
picture.php
picture.php
