Exhaust Housing and turbine s466-s480 twin setup
wes06dmax
Feb 23, 2009
1,367
South Central Kentucky
I'm planning on building a homemade twin setup using a S466-S480 I know this is popular setup and I know I can do the plumbing with no problem but my question is what the exhaust housing and turbine should be on the S466 and S480 so my drive pressure will be close any help will be appreciated
plowboy_lbz
Farmer
Aug 6, 2013
431
1.32 a/r with a 96mm is most popular. Some guys like the 1.10 a/r but its been said it will raise DP.
9,905
151
Sub'd. Interested in how this turns out.
I'm doing a 464/480 kit.
Sent from my C6906 using Tapatalk
Dirtymaxx03
3,109
s366 or an s466?
if you want the 400 frame secondary, go with the 83mm turbine (maybe the 87 if you gots lottsa fuel) and .90 AR. Get the 96mm/1.32 for the 80mm
