Hey guys Im new to the forum , and I am eagerly awaiting my LMM and 6spd Allison to arrive for a retrofit.
Basically the setup I am running is as above in front of a Atlas 4spd Transfer Case.
The question I have is that if I use the Atlas and don't opt for the VSS to be added, can I add an 'Exciter Ring' to the tail housing of the Allison on the output shaft like in a 2WD?
Can anyone help in the setup and advice on where to locate an Exciter ring for my setup.
Correct me if Im wrong but I am pretty sure it needs to be 40 tooth item for the TCM!!???
Cheers
Cheers
